C759 C659 thin lines on color IU at 60 K - 90 K
  • Norwaytech
    • Oct 2012
    • 7
    Hi, is there someone else that has got IU 712 M/C/Y that has not reach more than 30 -50 % life?
    I have 2 different machines with that issues so far.
    loks like there is some toner on the charge cl . and a very thin line on the drum..
    Just wondering that I am alone, and is there anything to do ?
  • MVPunisher
    • 209
    Re: C759 C659 thin lines on color IU at 60 K - 90 K
    I also have 2 different machines that fairly consistently have IUs fail early for thin lines.
      • 23009
      I can't explain why, but it's usually cyan that fails early. =^..^=
      • methogod
        • Dec 2008
        • 921
        off topic, but why did konica go back to IU in the CX59 series vs the CX58 series with DV units and separate drums for all colors?
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          What is the page coverage like?
          We have tons of c659-c759 in the field.
          It’s a roll of the dice for when the lines start but for us it’s usually pretty close to end of life anyway.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Because the c759 is just the continued evolution of a specific engine that started out as a CF2001.
            The smaller separate drum and dev engines are an evolution of the old c360 series.
            • methogod
              • Dec 2008
              • 921
              looking for either as a backup machine, mainly for scanning but light production, i like the split dv and drum units as drums fail before DV units.
              what are you thoughts on reliability and lower cost to operate?
              • uedele
                • Aug 2011
                • 15
                So i have just heard that there is a new wastebox come out for this model which helps with waste flow that will sort the I/U backing up pre maturely.
                • habik
                  • 2013
                  You are correct. There is a new waste box type with modified inside spacers/ columns to improve waste toner flow. It will have a small round plastic nip on the back side distinguish from the old box.
                  There is a tech. bulletin about it.
                  Sent from portable device using fast cheapset!
                  Firmwares HERE
                    There is a tech. bulletin about it. Sent from portable device using fast cheapset!
                    please post bulletin?
