C4050i magenta toner goes to PH
  • Bix
    • Apr 2018
    • 1421
    Hi, I did a couple of visits on a C4050i.
    On installation I found some toner in the PH glass. After cleaning with the cleaning stick, everything is ok. Initially I thought of a possible moviementato transport.
    After about a month, I came back to set up customer settings. The customer did not report any problems to me but I noticed an imprecise color again by printing the demo page. I found the magenta toner in the PH glass again. Currently TC has just over 1k
    Now I have also updated the firmware from G00-23 to G00-73.Has something similar happened to someone?
  • tsbservice
    Field tech
    • 8042
    Re: C4050i magenta toner goes to PH
    Bix, Good job by spoting the problems before client complains about.
    Not seen this so far but a couple of things:
    1. Only magenta PH window is affected first and second time?
    2. There were some threads here about IUs dumping developer and failed prematurely.
    I will do 30% solid coverage test on all 4 colors to inspect them for diminish developer and will check TCR ratios in SM.
    Next will do stabilize and gradations again if everything looks normal.
    • Bix
      • Apr 2018
      • 1421
      Exactly, only in magenta ph window. I noticed the problem by printing the univocal ones, I will keep an eye on it
