Konica C552 does not recognize A5 size on all trays and bypass
  • harcheshta
    • May 2019
    • 3
    Hi,
    My konica c552 does not recognize A5 paper size on all trays and bypass tray and when I put A5 Paper on one of the trays, it shows only "????" on that tray icon instead of "A5" , also I can not print to A5 size from computer, is there a solution for this problem?
    Thanks.
  • Bix
    • Apr 2018
    • 1421
    Re: Konica C552 does not recognize A5 size on all trays and bypass
    Hi, have you tried to see the back of the trayers?
    Are all plastics intact?
    • harcheshta
      • May 2019
      • 3
      Thank you for your reply,
      I checked the back of trays, all plastics are intact,
      The machine does recognize A4 and A3 paper sizes on all trays and bypass tray, but this problem is only when I put A5 papers on all trays even the bypass tray.
        • 22698
        Are you loading the paper LEF or SEF? It will feed SEF but is to short for LEF.
