SMB 2.0
  • jwai
    • May 2018
    • 508
    SMB 2.0
    Hi,
    I kindly to ask, the 8 series and i series both support SMB 2.0 on network scanning?
    Best regards,
  • Bix
    • Apr 2018
    • 1421
    Re: SMB 2.0
    Yes, it also supports SMB3.0
    For security, you could update the firmware
    • jwai
      • May 2018
      • 508
      Re: SMB 2.0
      Yup.
      The machine need to set the dip switch and specific F/W?
      ( It's bizhub 758 )
      • Bix
        • Apr 2018
        • 1421
        Re: SMB 2.0
        Hi, no dipswitch required.
        You can use dipsw 162-02 to disable SMB routing and you start from SMB2.0 minimum
        • jwai
          • May 2018
          • 508
          Re: SMB 2.0
          I found this :
          Admin setting->Network setting->SMB server setting->SMB server common setting
          Inside there have one " SMB auth. protocol ", SMB1.0 and SMB1.0/SMB2.0 either one can be selected.
          Here I can set it for the scan to server on SMB 2.0?
          • jwai
            • May 2018
            • 508
            Re: SMB 2.0
            BTW, KM don't provide full detail of DipSW on service manual, how we can get this stuff?
            • Synthohol
              Certified Konica Expert
              • 5823
              Re: SMB 2.0
              from a fellow member...
              • jwai
                • May 2018
                • 508
                Re: SMB 2.0
                Thank you for your information.
                Once I check that DipSW first.
                This SW219, what the difference with SW162?
                • Synthohol
                  • 5823
                  Re: SMB 2.0
                  You need to install the GDB firmware outlined in the above bulletin first then worry about the dip switch
                  • tsbservice
                    Field tech
                    • 8008
                    Re: SMB 2.0
                    Like Synt mention, with or without Dip Sw settings it will work with SMBv2 as soon as you install minimum FW version required.
                    Imho, do read more manual before posting new threads and try to follow up, never seen you reply with outcomes.
