Konica C6000 needs help
  • cxtqd
    • Jan 2011
    • 46
    Images printed on Konica C6000 machine are distorted, Experts please show how to fix them, thank you very much
    Re: Konica C6000 needs help
    hold on my crystal ball is warming up......
    there...
    what size paper?
    what feed direction?
    what tray are you printing from?
    are the paper guides on the tray tight to the paper?
    what are the condition of the feed and image parts?
    you really need to provide more info to us for us to lend aide ...
    I'm sure the other guys/gals here will need other info too.
    • cxtqd
      • Jan 2011
      • 46
      there...
      what size paper?
      Paper size A3 Plain Paper 80gsm, for all trays
      Parts is new
        Parts is new
        Guides tight on paper?
        Do test sheet skew the same as prints?
        • Synthohol
          Certified Konica Expert
          • 5808
          i only see a slight skew in the test pattern, have you initialized and done the both sides adjust for the trapezoid effect?
          • methogod
            • Dec 2008
            • 919
            hard to tell by your drawing is its skew or trapezoidal.
            loop adjusted?
            • cxtqd
              • Jan 2011
              • 46
              4 corners print irregular
              • Rohullah
                • Sep 2019
                • 37
                First you have to measure and adjust double side adjustment, mostly this happen in front side. If not solved, check the first feeding roller in right side of ADU, if the 2 roller pressure was not same, adjust pressure of rollers. Rollers pressure are changes when paper jamming in feeding roller.20191125_211322.jpg
