Bizhub C224e not detecting firmware
    replied
    Re: Bizhub C224e not detecting firmware
    Originally posted by Ari007
    I have a bizhub c224e, with low copy/print. The machine was running fine but had some deep sleep issues. Now, if the main sw is turned on it does the full warmup procedure(can tell from the sound) and gets stuck at two fins. If firmware is inserted from service port first it stays off and if main switch is turned on/off it again gets stuck at two fins.
    *SSD replaced
    *All the sensors are working
    *HDD is disconnected and disabled from service mode.
    Please help.
    How did you enter CE mode to disable the HDD if the machine wont boot?
  • Ari007
    replied
    Turn on machine while holding op panel's Power button, wait for a beep. Do self diagnostic and look for any NG results, probably if it fails at second pillar(fin) some memory tests will fail.
    I've already ordered replacement RAM.. hopefully will get it within two days.. I'll try this
  • tsbservice
    replied
  • Ari007
    replied
    sounds like you need a service manual
    I already have.. and went through the procedures.. this is an uncommon problem..
    replied
    *SSD replaced
    Please help.
  • Ari007
    started a topic [Misc] Bizhub C224e not detecting firmware
    *SSD replaced
    Please help.
