Bizhub C224e not detecting firmware
  • Ari007
    • Apr 2019
    • 49
    [Misc] Bizhub C224e not detecting firmware
    I have a bizhub c224e, with low copy/print. The machine was running fine but had some deep sleep issues. Now, if the main sw is turned on it does the full warmup procedure(can tell from the sound) and gets stuck at two fins. If firmware is inserted from service port first it stays off and if main switch is turned on/off it again gets stuck at two fins.
    *SSD replaced
    *All the sensors are working
    *HDD is disconnected and disabled from service mode.
    Please help.
    Re: Bizhub C224e not detecting firmware
    *SSD replaced
    Please help.
    sounds like you need a service manual
    • Ari007
      • Apr 2019
      • 49
      I already have.. and went through the procedures.. this is an uncommon problem..
      • tsbservice
        Field tech
        • 8020
        Turn on machine while holding op panel's Power button, wait for a beep. Do self diagnostic and look for any NG results, probably if it fails at second pillar(fin) some memory tests will fail.
        • Ari007
          • Apr 2019
          • 49
          I've already ordered replacement RAM.. hopefully will get it within two days.. I'll try this
          • copier tech
            • 8174
            *SSD replaced
            Please help.
            How did you enter CE mode to disable the HDD if the machine wont boot?
            • qbert69
              • Mar 2013
              • 1152
              *SSD replaced
              Please help.
              SSD Brand New or Pulled from another machine???[emoji848]
              Sent from my SM-N950U1 using Tapatalk
              REACH FOR THE STARS!!!
              Konica Minolta Planetariums!
              • allan
                RTFM!!
                • 5462
                Yea the reset tool comes to mind.
                Should boot into diagnostic mode to test RAM.
                Whatever
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4723
                  Agree use the firmware reset tool.
                  Also try booting up with service USB port open but no flash drive in it. It should boot up so you can get into service mode etc
                  • Ari007
                    • Apr 2019
                    • 49
                    Disabled when the machine was running fine... a week ago
                    • Ari007
                      • Apr 2019
                      • 49
                      SSD is brand new..
                      • Ari007
                        • Apr 2019
                        • 49
                        I've tried reset tool but not detecting.
                        • Ari007
                          • Apr 2019
                          • 49
                          Tried this but two bars.. installed new RAM... Same results
                          • Ari007
                            • Apr 2019
                            • 49
                            When I started it in the morning with the new RAM installed, it started to boot then restarted and then stuck at 4 bars..
                            • rrrohan
                              • Sep 2011
                              • 1977
                              have you applied the SSD V6.05 firmware?
