How to Set Konica Minolta 4 Sereis Auto Counter Emailing with Detail
  • denvertan
    • May 2019
    • 82
    [Misc] How to Set Konica Minolta 4 Sereis Auto Counter Emailing with Detail
    Current I only received the counter email with Total Colour and Total Black.
    But my charges is A3 is 2xA4.
    How to I set the counter listing to enable 1xA3 = 2xA4
    Or show both A3 and A4 counter in the email. TQ TQ
  • Synthohol
    Certified Konica Expert
    • 5840
    Re: How to Set Konica Minolta 4 Sereis Auto Counter Emailing with Detail
    it already does count it.
    if you print a meter sheet you will see the count for large.
    you can verify at the machine service mode, stop 9 counter setting mode 2
    • denvertan
      • May 2019
      • 82
      I did the checking and this is what I found.
      0. Print the counter listing
      1. Print 1 sheet A3 colour
      2. Print the counter listing again.
      Total colour does increase by 1. (How to I make it increase 2 ?) Because 1xA3 = 2xA4.
      • allan
        RTFM!!
        • 5462
        Just test it if you are at the machine. Don't know if there is any way to change that email format.
        Should be set to double for large size by default but like Synthohol mentioned it can be changed under billing mode.
        Whatever
        • denvertan
          • May 2019
          • 82
          Will try to test it tomorrow.
          Once done will update here.
          TQ.
          • tsbservice
            Field tech
            • 8019
            Unless the machine is setup for Japan it should count A3 as large size is double counts.
            • denvertan
              • May 2019
              • 82
              Thank you for guidance.
              The copier setup is mode 1 before this.
