Konica Minolta C652 - black toner issue
  • Kenny
    • Jun 2009
    • 526
    Hi guys,
    We seem to having an issue with one of our C652s. The black toner level on this machine always says it is low and then says replace toner. We have replaced the toner multiple times, we have managed to get it to say its full then after about a day its says its low and then replace toner again. The machine is on the latest firmware.
    We have replaced the following:
    Black toner with a Genuine x2
    Toner Hopper Unit x2
    PRCB
    Black drum and Developing unit
    Any suggestions would be helpful.
  • Bix
    • Apr 2018
    • 1421
    Re: Konica Minolta C652 - black toner issue
    Hi, it's a known "problem" in Konica Minolta machines.
    This is because there is no real sensor that quantifies the actual amount of toner. The best solution is to replace the toner only when it ends completely. In this way, the printer will adjust again.
    There are also dipswitches for reset, but at the moment I don't know if they work with C652.
    • Kenny
      • Jun 2009
      • 526
      Thanks for the reply,
      The machine does say it has ran out of toner and is empty when we first came to this issue, then we replace it but like I say it goes back to low toner after a day
      Could possibly try those software switches? will try anything at this moment haha!
      • Bix
        • Apr 2018
        • 1421
        Hi,
        see this:
        Wrong toner indicator bizhub 227
        • copyman
          Owner / Technician
          • Sep 2005
          • 4676
          What version F/W is in machine? I searched knowledge base and this is special F/W for toner levels, fluctuates from proper level to zero. F/w should be GZZ D6
          Also see attachment addressing this issue
          • tsbservice
            Field tech
            • 8006
            It may be toner bottle drive or motor, easy to see. Check the new toner weight, if full but there is low toner message on the machine, drive is faulty. Or you can mark bottle and run toner motor in Load check, just a couple of ideas.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4676
              Good call, I believe the attached bulletin I posted is for the btl drive.
