C7000 pro with black not registering
  • mshabban
    • Jan 2017
    • 101
    Hello guys ,i am sorry ive got too many issues at ago,i have this other machine not registering black,orher colors are ok ,without issues or errors ,but i have also changed parts and pwbc from working machines but still getting same issues ,black not registering ,i dont know what am missimg out really ,any tech help will be much appreciated.
    Re: C7000 pro with black not registering
    is the toner for this model?
    Genuine OEM Toner - compatible ?
    have you checked contacts in unit and on cart for clean straight contacts?
    any TABS/packing materials removed improperly?
    can you post service logs sheets?
    what parts/pwbc have you swapped?
    sorry Bro.. my Crystal Ball is on the fritz!
    PhilB. "The Dentist"
    • Arcadian
      • Feb 2010
      • 218
      most konica have a calibration method, or procedure on them, its in tech mode, even if you swap out all drums it'll still be out of registry, so look for color calibration or drum registry
      • Herrmann
        • Jan 2006
        • 792
        Just wondering...
        Black is the reference on these models,
        maybe black is correct and the 3 colors are out of spec?
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • 22999
          Originally posted by Herrmann
          Just wondering...
          Maybe I'm wrong ... but I think he means that he's not getting very good black density, not an issue with color registration. My guess is that the main issue is inaccurate translation.
          I'm also guessing that he's not a technician since he makes no mention of calibrations, developer stir, error or jam codes ... or anything else that requires experience and a manual. I'm guessing he has neither. =^..^=
