KM Bizhub C353 page coming out tinted yellow when doing color prints/copies
  • Riviera
    • Sep 2016
    • 66
    All color units installed less then 10k and 4 months ago. Customer says the tinting started soon after but only recently called. I suspect yellow is over toning.? Is there anyway to correct with out replacing?
  • Synthohol
    Certified Konica Expert
    • 5463
    Re: KM Bizhub C353 page coming out tinted yellow when doing color prints/copies
    OEM toner?
    if only 10% life they are covered under 100% warranty replacement.
    • Synthohol
      • 5463
      You could try running a background data reset and stabilize under stabilizer and then do your gradations
      • tsbservice
        Field tech
        • 7635
        Just what client says is not relevant and not enough. You should go there and check by yourself. I can't count how many times they(endusers) were misleading me by the problem description.
