Awakening from causal energy savings
  • Bix
    • Apr 2018
    • 1421
    #16
    Re: Awakening from causal energy savings
    Hi, I confirm after several weeks that the solution is effective! Keep going regularly to standby. Only strange thing, I hear the speaker making a small noise (as if knocking) every minute.
    Another thing, one morning I tried to wake her up, the MFP didn't wake up in any way. I have the default power settings, what do you think is the option that could cause this?
    • Bix
      • Apr 2018
      • 1421
      #17
      Ummm ... yesterday I think I brought bad luck.
      The C250i has started to turn itself on again, even with the ground wire
      • Bix
        • Apr 2018
        • 1421
        #18
        Update: I've fixed the cable better and it seems to go back to standby.
        But I have two curiosities:
        1. I notice that the display when you touch it sometimes from a feeling of static electricity.
        2. Does a new display have a grounding cable or is the proximity device simply changed? Did any of you understand what exactly causes this?
        • tsbservice
          Field tech
          • 8032
          #19
          Mine machine sleeps like a champ after this mode. I have a feeling that some of first produced C250i had something wrong maybe MFPB minor change on later produced machines.
          • occus
            • 338
            #20
            After a test with the ground cable on 3 machines inhouse for 2 weeks i thought we had the solution but now i have a 250i GC1-75 which still wakes up again and again...
            • Bix
              • Apr 2018
              • 1421
              #21
              I advise you to add a washer under the screw that connects to the ground. C250i also casually started waking up to me after this solution. The cable, although apparently well connected, was not. After several movements of the monitor, something has moved. Perhaps the grounding made a false contact being slightly larger than the screw.
              • tsbservice
                Field tech
                • 8032
                #22
                There is new FW available ver. G00-79
                • Bix
                  • Apr 2018
                  • 1421
                  #23
                  Yes, I have seen it too, but the logs are always the same. Apart from some translation improvements, it seems that they always solve the usual problems that have theoretically already been solved
