konica minolta bizhub 4020 error 900.00
  • zeca
    • Apr 2019
    • 16
    Hello, this copiar machine not copier and not scan documents. display error 900.00 plase help.
    https://t.me/pump_upp
  • Synthohol
    Certified Konica Expert
    • 5848
    Re: konica minolta bizhub 4020 error 900.00
    4.6.13 System software error service check
    There are different types of 900.xx errors that can occur. There may be a communication problem (bad
    cable, network connection, and so on) software issue, or a hardware problem with the controller board,
    or ISP (internal solutions port). The communication and software aspects should be checked first.
    Determine if the problem is constant or intermittent. Use the troubleshooting procedure below to isolate
    the issue. Take any notes as instructed. You will need that information in the event you need to contact
    your next level of support.
    • tsbservice
      Field tech
      • 8020
      Those are RIP firmware errors.
      Clear all print queues from print jobs.
      Reboot the machine with network cable disconnected.
      If problem repeat after connecting network do restore factory default from the Configuration Menu.
      If anything works for you may have to replace controller board...I personally would blame poor Lexmark design and throw it in the bin.
      • zeca
        • Apr 2019
        • 16
        The problem error is solved. The copier, not is possible scaning or copir. The message displayed is scaning... infinit time.
        • Gerg?
          • Jul 2008
          • 67
          Hello Zeca,
          Can you help me? What was the solution?
          Thank you
          Gergő
          • zeca
            • Apr 2019
            • 16
            Hello, no solved.
            • korthr5
              • Feb 2016
              • 39
              Zeca
              On 4050 the problem is the ADF.
              When the machine is starting you listen the ADF testing the pickup arm ?
              Regards
              • Gerg?
                • Jul 2008
                • 67
                Hello, no solved.
                Bad news.
                • Blizzoo
                  • Aug 2013
                  • 608
                  Everytime I had 900.x errors on Lexmarks it was a corrupted print job (mainly stuff printed direct from Explorer/Edge) or bad driver. Follow tsbservice guide, clear print queues for any stuck jobs, reinstall print driver and maybe a FW update if it's possible.
