C2650 code on Bizhub-223
  • dmw
    • Feb 2010
    • 17
    [Error Code] C2650 code on Bizhub-223
    We were faced C2650 in Bizhub-223 around three months before, but it was clear simply by Trouble reset, after that machine worked perfectly but now have this code again and not to be going off in either way.
    Has anyone seen this issue before?
  • mo0651
    • 1054
    Re: C2650 code on Bizhub-223
    Dealing with 1 now. It is the EEprom on the PRCB board on ours. trying to get a part # to replace it. You are not supposed to use a used part.
    • Synthohol
      Certified Konica Expert
      • 5892
      Ye s. Ssd boards are special order through km dealers only.
      Try just reseating it. Take out the screw, pull it off, blow off the contacts and when you reinstall and tighten the screw, pus the ssd board above the connector so it does not skew.
      • mo0651
        • 1054
        Nope not the NVRAM. This is on Printer Control Board. Little 6 pin eeprom that you change over if you have to replace that board.
        • Synthohol
          • 5892
          what model are you on? the 223 has no eeprom on the prcb that i can see in the parts manual or remember ever seeing.
          • escalante
            • Sep 2018
            • 115
            I hope this document helps you solve your problem.C2650 code at machine power up..pdf
            Enviado desde mi SM-J701M mediante Tapatalk
            • allan
              RTFM!!
              • 5462
              Could help to just reinstall it. Could be creeping out of the socket.
              Believe it contains data like the TCR value and life counter values.
              Don't need to change it out but could help to avoid C2557 C2558 problems.
              But i could be completely wrong.
              Whatever
              • tsbservice
                Field tech
                • 8053
                Actually it has 1 IC51 EEPROM mounted on PRCB. When PRCB is replaced old 8 pin EEPROM have to be remounted onto new PRCB.
