66-01 df628 bizhub 227
  • Bix
    • Apr 2018
    • 1421
    Hi, I want to consult with you about a 66-01 jam code on the Bizhub DF-628 227.
    I always had this problem on the same MFP about 6 months ago and I solved it by cleaning the rollers and blowing dust from the sensors.
    The scan counter is only 30k.
    But this problem seems to recur now. I could try cleaning again but I wonder if any of you have any more suggestions to give me.
    Every time with the DF is an adventure. There doesn't seem to be anything dirty in the sensors but after cleaning, they magically start working again.
  • Leyahné
    • Feb 2016
    • 44
    Re: 66-01 df628 bizhub 227
    Have you changed the take up rollers?
    Sent from my SM-N960F using Tapatalk
    • Bix
      • Apr 2018
      • 1421
      The take up rollers are almost like new, theoretically they should be replaced after 200k uses. It currently only has 30k
      I believe that in the end the problem is generated by paper dust. I should perhaps equip myself with a can of compressed air or a straw to blow at the deepest points.
      • mo0651
        • 1054
        How many scans thru the ADF??? May be higher count. What type of originals??
        • Bix
          • Apr 2018
          • 1421
          MFP has a counter for ADF. Currently less than 30,000. It happens with normal A4
          • tsbservice
            Field tech
            • 8020
            I would start with checking original registration sensor PS3. KonMin sometimes uses black felt pads as non reflective surface and paper dust accumulation on pad may create false readings of sensor. Also teach customers to scan originals with holes SEF if possible because on some models holes match sensors and create jam conditions.
              those SHOULD be a staple in your tool bag.. or even a small blower brush
                • 14785
                This jam code is related to duplexing. Have you had the inner cover off and cleaned everything under there? There are rollers and sensors that get dirty and dusty.
                  • 23009
                  66-01 is a pickup jam. Rollers might be dirty or coated with NCR coating. Machine count doesn't mean much. They could have done 1M scans entirely unrelated to printing. =^..^=
                    • 14785
                    66-01 Misfeed at DF turnover section <When DF-628 is installed>
                    • tsbservice
                      Field tech
                      • 8020
                      So for me Bix clearly stated that rollers are cleaned a few times and ADF scan counter in service mode is around 30k...and still most of the coments are to say at best... perplexing
                      • tsbservice
                        Field tech
                        • 8020
                        Agree with that, I would concentrate on Original switchback exit roller and original exit roller release solenoid operation.
                        • Bix
                          • Apr 2018
                          • 1421
                          Thank you all for the advice. At the end this thread is to collect in general the best skills to deal with DF's jam
                          • Bix
                            • Apr 2018
                            • 1421
                            I refresh the thread. I have many Bizhub 227s in the field and I must admit that this code is very common. For now, the codes are always solved with a general cleaning of the rollers and sensors but it happens that after a few months the problem returns.
                            I have seen that the parts code of the DF has undergone several changes. In conclusion, it is bad and slow. But chip is good, so it's ok
                            • allan
                              RTFM!!
                              • 5462
                              Yea depends on what they put thru there. Some guys like to put docs straight out of there inkjet in there.
                              Had a machine in a spice packaging plants and the picking slips that returned was soiled.
                              Not the best option but i had to instruct them to clean the rollers every other day.
                              The companies i worked for never billed for scans so its unfair to drive out there every other day.
                              Have a good look at everything again. Make sure the latch pins that holds the cover down are not bent up slightly, or that you don't have a broken latch hook.
                              Whatever
