Re: J-7229/J-7217/J-7216 & Both Sides Adjustment
The pic I posted is of one of our FS-607 finishers, if you take the top cover off you'll see it inside siting on top of the paper exit slide stay towards the back side - if you look on P 9 of the parts manual it's labelled SD4 part 10.
The solenoid operates the finger plate which you can just about see in your original pic just below your red box and goes in-between the rollers, it drops down enabling the paper to contact the rollers as the paper passes through.
If the rollers don't resolve the problem, just check the idler shafts I mentioned, these are on page P11 of the parts manual labelled 18/19 - in our case these were preventing the slide assay from lowering far enough.
FYI you mentioned the foam roller on the far left not having any foam, we've had 5 of these type of finishers and I don't think any have had foam on that roller either.
Gutted for you on the LU202, I can't imagine that being an easy fix winding all that lot back together and getting it balanced, good luck!
And sorry to hear the chart adjustment didn't work for you...
See you around
Mark
See you around
Mark
