USB Local Printer
  • emujo2
    • Mar 2017
    • 1579
    #16
    Re: USB Local Printer
    Originally posted by qbert69
    I have never figured out why a printer/mfp would be a "security risk" and as usually configured, operates on the LAN behind a firewall!!! Only way to get in from outside is if the IPort was pinholed!!! Now if the threat was from the inside, it would be from one of the pc's scanning open ports of devices to try & exploit!!![emoji15]
    Sent from my SM-N950U1 using Tapatalk
    Tell that to one of my customers (large college campus with 100s of MFPs) that came in over the weekend and found some hacker had tunneled in through port 25 and had every MFP run print jobs until paper was depleted. In some cases, the users saw the flashing add paper message and reloaded..I'm not saying that you can use the copier to launch a nuclear weapon strike, but some of those older machines def had weaknesses. All you need is some SMB password to be stored in clear text, and you have a entry onto the system. E
    • qbert69
      • Mar 2013
      • 1152
      #17
      Apparently that was before IP range filtering!!![emoji23][emoji1787][emoji38]....and port 25, isn't that smtp no authentication?![emoji23][emoji1787][emoji38]
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • emujo2
        • Mar 2017
        • 1579
        #18
        Yes, this was the customers preferred method of scanning..Internal only port 25, no authentication..There was also some fault to the local IT for allowing this. E
        • mo0651
          • 1054
          #19
          What a waste of time!!! no one in right mind mind would connect a C258 to one user via usb. Unless in a house by themselves. Usb only good for like 16 feet away. You can see the
          OP Panel from there and tell if it is low on toner!!
          Most cheap ink jets have a part of the software that shows POP UPS with low ink levels.
          Big price difference between the 2 models you have listed in opening post.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            #20
            Some years back I had a Ricoh MP 161 in a state office.
            Their policy was that no printer was to have a network connection, USB or parallel connections only. The machine was connected USB to one workstation, and was a shared printer for the other 3 or 4 workstations near it which were given access to print.
            Every few weeks or so for about 6 months they kept calling us to set it up as a scanner, and each time I had to explain that it was no banana until they granted network access. That model did not have Scan to USB capabilities.
            I even suggested a second NIC in the host PC with a crossover cable, but the buttweed IT guy was having none of it.
            โ€œI think you should treat good friends like a fine wine. Thatโ€™s why I keep mine locked up in the basement.โ€ - Tim Hawkins
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              #21
              Originally posted by dannu
              Hello! I would have a problem having 1 USB printer (Lexmark Mx823 or Minolta C258) connected to 1 computer. The pc internet has but 1 ethernet port. Is there a solution to read counter via USB? I found "https://printcounters.com/" but USB doesn't work just blinks minolta.
              Anyone else idea?
              Those spam bots must be getting better. That post almost made sense.
              • qbert69
                • Mar 2013
                • 1152
                #22
                Dippy Dannu Disappeared off the Radar!!![emoji38][emoji23][emoji1787]
                • dannu
                  • Jun 2016
                  • 25
                  #23
                  I'm here. I live in Hungary. People are very stupid here. I know a simple solution would be 30 pieces of 5 prot swich.
                  • dannu
                    • Jun 2016
                    • 25
                    #24
                    QUESTION: What do you define a "proper" network to be in your own understanding???[emoji848]
                    Goal, Perception, Expectation...define each. Communicate with the customer. Give them an ultimatum that they need to respond to. [emoji41][emoji1303]
                    There are several ethernet ports in one office per network.
                    • dannu
                      • Jun 2016
                      • 25
                      #25
                      You have 30 printers at this site? & you need ALL users to ONLY print via USB!? How many users in this building!?
                      You need to sit down with their IT dept & have a serious chat about setting up a network even an Intranet if they are worried about security.
                      This is a hospital. One doctor, one computer, one utp connector. This is Hungary's stupid paradise.
                      • habik
                        • 2013
                        #26
                        What a great opportunity to sell them HDD SECURITY package.
                        4 port Switch cost can be swallowed in the HDD SECURITY package. There you can have them being lazy and they can read the counter from the pagescope connection or set them up to email the readings..
                        Sent from portable device using fast cheapset!
                        Firmwares HERE
