USB Local Printer
  • dannu
    • Jun 2016
    • 25
    USB Local Printer
    Hello! I would have a problem having 1 USB printer (Lexmark Mx823 or Minolta C258) connected to 1 computer. The pc internet has but 1 ethernet port. Is there a solution to read counter via USB? I found "https://printcounters.com/" but USB doesn't work just blinks minolta.
    Anyone else idea?
  • qbert69
    • Mar 2013
    • 1152
    Re: USB Local Printer
    Anyone else idea?
    Add a 5 port network switch & 3 short ethernet cables. Configure appropriately. [emoji41][emoji1303]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • dannu
      • Jun 2016
      • 25
      Tooooooo easy , its ver very security and danger zonne and zombie error and omg .....
      Too easy
      • qbert69
        • Mar 2013
        • 1152
        Too easy
        Whiskey Tango Foxtrot???[emoji848]
        • mo0651
          • 1054
          TOOO HARD TO GO TO c258 AND TOUCH "MENU" "COUNTER" and read???
          • qbert69
            • Mar 2013
            • 1152
            Too easy
            Are you talking about some kind of security risk???[emoji848]
            • dannu
              • Jun 2016
              • 25
              Customers are lazy ....
              • dannu
                • Jun 2016
                • 25
                There is no proper network in the building. Each office has 1 ethernet port, no other device should be used.Thirty printers will be installed. A3 and A4.There is no proper network in the building. Each office has 1 ethernet port, no other device should be used.
                  • 15072
                  Are you trying to say you are not allowed, by the customer, to install a network switch?
                  • tsbservice
                    Field tech
                    • 8082
                    If this group of paranoics won't let you install anything how you imagine they would agree to install software collecting counters and sending them outside
                    • qbert69
                      • Mar 2013
                      • 1152
                      QUESTION: What do you define a "proper" network to be in your own understanding???[emoji848]
                      Goal, Perception, Expectation...define each. Communicate with the customer. Give them an ultimatum that they need to respond to. [emoji41][emoji1303]
                      • emujo2
                        • Mar 2017
                        • 1579
                        We had a problem similar to this some time ago..We replaced one vendor with KM products. Someone did not do their research and it was discovered that the customer's security team would not allow the printers to be placed on the network, only local USB connections. The problem was the old machince gave some kind of user interface via USB, the KMs did not. We would up installing USB to ethernet adaptors. USB on the PC side, Cat 6 cable to to MFP..Configured the adaptor and machine with mactching IP schemas and 'viola" probelm solved. ( we had to eat the cost of the adaptors).
                        • qbert69
                          • Mar 2013
                          • 1152
                          I have never figured out why a printer/mfp would be a "security risk" and as usually configured, operates on the LAN behind a firewall!!! Only way to get in from outside is if the IPort was pinholed!!! Now if the threat was from the inside, it would be from one of the pc's scanning open ports of devices to try & exploit!!![emoji15]
                          • copier tech
                            • 8237
                            You have 30 printers at this site? & you need ALL users to ONLY print via USB!? How many users in this building!?
                            You need to sit down with their IT dept & have a serious chat about setting up a network even an Intranet if they are worried about security.
                            • qbert69
                              • Mar 2013
                              • 1152
                              Just from the info gathered, it almost sounds like a rental office situation where every office cubicle is rented out by a broker or....a bookie...just to keep things private and separated!!![emoji2958]
