problem with firmware KONICAMINOLTA BIZHUB C360
  • tecnomarco
    • Jul 2011
    • 214
    I was updating the firmware of the konicaminolta c-360 while the controller update was in progress and the writing "dowload n.g." appeared and the "red" print button remained while all the other items updated them all ... now the hourglass appears and it does not restart can you do something? can anyone give me a suggestion thank's
    Re: problem with firmware KONICAMINOLTA BIZHUB C360
    1) are you sure you uploaded the correct firmware?
    2) what problems did you have to require update?
    3) did you follow the process EXACTLY when preforming the update?
    4) how did you perform the update?
    I know there was multiple discussions on this machine with that issue. Have you checked out the other threads?
    • tecnomarco
      • Jul 2011
      • 214
      thank Phil.. i have bought this copier but language italy is missing, this is the firmware A0EDFW , via rear USB port but SCANNER IS OK ...ADF IS OK..ECC... MFC CONTROLLER ....DOWNLOAD N.G.
      • Synthohol
        Certified Konica Expert
        • 5816
        yeah, upgrade to a supported machine.
        parts, supplies and support have ended last month.
        • tecnomarco
          • Jul 2011
          • 214
          can someone give me a firmware previous to this or suggest a solution thanks
          • tecnomarco
            • Jul 2011
            • 214
            I tried to reformat the 4 GB key the copier tries to update the firmware but after a minute the word DOWLOAD N.G. reappears.
              • 14668
              One of the items will show NG. Meaning, most will show OK, but one of the items will not be downloaded. Maybe fax or finisher. Check the second page on the firmware download screen. Sometimes if you uncheck all the ones that downloaded properly and just check the one that didn't it will work.
              • tecnomarco
                • Jul 2011
                • 214
                the second screen is empty, and I also tried to download only the MFC CONTROLLER firmware but it does the same problem
                • Synthohol
                  • 5816
                  disconnect the finisher, doc feeder, additional paper feed cabinet, fax and try again.
                  • tecnomarco
                    • Jul 2011
                    • 214
                    thank, for your suggestion but t doesn't work i did as you suggested
                    • tecnomarco
                      • Jul 2011
                      • 214
                      a greeting to all ... I need a firmware not the latest of a konicaminolta c360 in particular I have to change the display language in Italian .... the latest controller firmware I can't install it tells me "downloading N.G." if someone can send me the file also of the older firmware versions in order to restore the functioning my email is: tecnocopia2000@libero.it thank you in advance it is urgent
                      • tecnomarco
                        • Jul 2011
                        • 214
                        I solve this problem with a OLD PEN DRIVE 4 GB a modern pen drive is not good
