Fiery RIP for Konica 7920?
  • AKSturb01
    • Jul 2009
    • 27
    I have a Konica 7920 with the onboard Fiery PostScript RIP/Hard Drive/Network adaptor that still works...sort of. It starts up normally and will copy from the scanner glass, but the RIP is dead.
    After about 1 minute trying to "Loading System" the yellow warning light goes on:
    "Boot Failed. No Boot Device."
    I assume this means the Fiery hard drive / RIP board is dead.
    Does anyone know where I can get one of them? Is it possible to replace it?
    Thanks in advance.
  • Synthohol
    Certified Konica Expert
    • 5806
    Re: Fiery RIP for Konica 7920?
    Z4 controller or the X3e?
    • AKSturb01
      • Jul 2009
      • 27
      It's the X3e, internal.
      • Synthohol
        • 5806
        well even though you are not a contributor your rep count vs post count is admirable.
        you can use most any laptop HDD to replace and i can PM you a link to the system software disks on my server.
        if you need the manuals too let me know, IIRC there is a special parallel to scsi cable you will need.
        good luck!
        • AKSturb01
          • Jul 2009
          • 27
          good luck!
          Thank you very much, I'll be in touch.
          • tsbservice
            Field tech
            • 7981
            Lol first color machines I worked on Toshiba FC 15/22 were with that Fierys. Long buried now, but what a memories 💾☎
            • Synthohol
              • 5806
              that model looks like the CF1501/2001 or maybe the CF3102.
              reloading system software requires the scsi to parallel cable, some LPT1 tweaks and a whole lotta prayer.
              id just set it on fire and run personally
