USB thumb drive does not work with 4,4e,8,8e or i Series
  • tsbservice
    Field tech
    • 7929
    [Misc] USB thumb drive does not work with 4,4e,8,8e or i Series
    As I read many threads here that FW updates going wrong way or techs have to use twisted workarounds to update the FW, fellow techs be aware of information below:
    Windows formatting may prevent USB thumb drive from being read correctly and will fail if used to flash firmware on 4,8 or i series MFPs
    - Sometimes error messages dealing with Write Protection, or unreadable disk, etc may occur
    - When inserted into the machines the firmware will simply not load, or not load properly
    How to and program to format the USB thumb drive cleanly are to be found in KBA00053111
    Basically don't use Windows to format thumb drive but other utilities, if needed use comand prompt to clean the thumb drive and reset the MBR.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4553
    Re: USB thumb drive does not work with 4,4e,8,8e or i Series
    Thanks for the heads up. I looked on dealer website and could not find that bulletin. Can you PM it to me or point me in right direction. K/M site is so weird to search stuff!
    Thanks again
    • Lync
      • Feb 2016
      • 47
      Use GUIFormat to format it in FAT32. If the USB drive doesn't work after this, you might need to get another USB drive.
      You can get it from here:
      Ridgecrop Consultants Ltd
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        We just started using rufus to format thumb drives since Windows is a no no. rufus is open source and works well with a portable version that doesn't need installing.
        Rufus
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
