658e prints completely black
  • Bix
    • Apr 2018
    • 1421
    Hi, I have a bizhub 658e with 280k and it has started printing with white lines and a little dark. I use only OEM.
    As foreseen in the manual (300k) I have replaced: transfer belt, 2nd transfer roller, toner filter and drum.
    But something went wrong. The drum has some problem why because the printer prints the whole sheet completely black! By putting the old drum back, this does not happen. Maybe a new defective drum? As soon as I removed the drum, near the charge roller I saw it has a piece of broken plastic. I honestly don't know how to take these drums apart, so I think I'll try another new drum. Has this ever happened to you?
  • tsbservice
    Field tech
    • 8077
    Re: 658e prints completely black
    Bix, don't have such machine but if I were at your place will put another new drum into machine.
    Next at the shop when you have time rebuild drum unit with broken part with this part from original one drum.
      • 23010
      Not me but certainly plausable. =^..^=
      • mo0651
        • 1054
        Are you positive you have correct Drum??
        • AL parts
          • Jun 2019
          • 61
          Try to install the old drum's PCR to the new drum
          www.gzanling.com
          • Bix
            • Apr 2018
            • 1421
            yeah, if I remember, it is DR314
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              I had this happen on a C558. Broken holder for the charge roller, from the factory. Had to RMA it and get a new drum.
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • Bix
                • Apr 2018
                • 1421
                Hi, yes I confirm.
                A piece of white plastic from the charge roller was swept. I took a used drum and I replaced the piece. The only problem is the chip which does not reset but is not essential
