Minolta C458 paperjam 9901
  • furius
    • Jan 2018
    • 34
    Hi guys, I have a problem on a C458, on tray 1 after some printing the machine jams with code 9901 and an error related to the paper size not recognized. .
    The machine has 100,000 copies.
    If i use tray not have problem.
    I have already tried to replace the paper pick-up rollers,clutch and torque the problem persists.
    Do you have any suggestions?
    Thank you very much!
    Re: Minolta C458 paperjam 9901
    why the EXTRA large font?
    doesn't make it more important
    are the size n type of media set properly in File and copier?
    what paper are you trying to print on?
    age on service parts?
    coated or plain?
    you don't give us much to work with
    • Bix
      • Apr 2018
      • 1421
      Hi, in what sense is the paper size not recognized?
      When you try to go to the copy window, what appears to you about Tray 1? is the correct size or have the tray settings been changed?
      If it appears "???" make sure there is no jammed paper in the back of the tray. If there is not even paper, make sure that the plastic pieces in the back of the tray that identified the paper size have not broken.
      • copier tech
        • 8195
        Try changing SW145 set HEX to 02 this will display a size mismatch but not a jam.
        • jalaoly
          • Jul 2014
          • 10
          Hi guys,
          I have this problem on 2 C458 and i solved it with changing registration sensore and clutch registration
          • antone
            • Oct 2014
            • 344
            What clutch and what registration sensor??
            Sent from my SM-N981U using Tapatalk
            • jalaoly
              • Jul 2014
              • 10
              • fishleg
                • Mar 2009
                • 426
                9901 - just thinking of previous models especially out the bottom trays the conveyancing rollers at the side would slip and you'd get 9901. Some engineers used to add shims to the hooks to apply more pressure. If it doesn't do it from tray 1 the machine is probably just struggling with the paper well in terms of moving it up the vertical feed before the registration or could be as daft as the spring has fell off the registration sensor.
                • and
                  • Oct 2011
                  • 97
                  Originally posted by jalaoly
                  [ATTACH=CONFIG]49342[/ATTACH]
                  I had one C458 with same problem, i increased the tension of spring of the PS1 sensor that you have changed.
