Bizhub 454e cannot print/copy
  • Cliff12341
    • Jan 2019
    • 4
    I've got a bizhub 454e that whenever you try to copy/print to the machine, it sits and thinks for a second but never actually passes paper. It will scan to email successful, just can't get paper to move through the machine. Nothing in the service history/no error codes related to the issue. Anyone seen this before?
  • guitar9199
    • Sep 2016
    • 1100
    Re: Bizhub 454e cannot print/copy
    Only thing I've seen even remotely like this is a machine that doesn't have PostScript installed, but someone tries to print using a PS driver. That would only affect printing though...wouldn't have anything to do with copying.
    My first thought would be to reflash all the firmware.
    • tulintron
      • Jul 2014
      • 668
      You can also perform initialization / clear all data.
      maybe some user control data is inhibiting these
      services.
      remembering that after booting, hdd disables,
      being necessary to enable, update and configure network.
        • 23010
        Account Track/Authentication enabled? =^..^=
        • tsbservice
          Field tech
          • 8081
          Sounds like consumables are over due and machine is set to Stop, less common but still happens.
          Can you post Consumables page?
