FS-533 Finisher Question
  • SAR
    • Jul 2009
    • 203
    Never had this one before, but I have a customer who said the FS-533 is driving him crazy because the tray drops down and rises back up between each job and when he runs multiple jobs in a row it is slow. Is there a setting or a way to make the finisher tray just stay in the up position and not drop down each time?
    Thanks!
  • Synaux
    • Mar 2012
    • 1224
    Re: FS-533 Finisher Question
    Thanks!
    Isn't the 533 internal? Shouldn't take that long, I recall some discussion on here about modding the tray full actuator on these, but that is different than what you are describing.
    • Synthohol
      Certified Konica Expert
      • 5809
      is that called continuous print? i dont remember but i think it is from my production machine days.
      • jwai
        • May 2018
        • 508
        The Engine DipSW can do so.
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          Well, I'll be darned. It's right there in the service manual and I had no idea that option was there. I learned something today, so thanks for that!
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • SAR
            • Jul 2009
            • 203
            Thanks so much jwai. Here is the procedure to set this up:
            How to set FS-533 receiving tray to stay in up position.
            1. Go into Enhanced Security mode (Go into Service Mode, then touch stop, 0, C.)
            2. Touch Engine FW Dip SW (If this button is not displayed, you have to enable it by going into Service Mode, System 2, Software Switch Setting and set SW 59 TO Hex 01.)
            3. Touch box #18 to highlight it, then touch End. Turn copier off/on.
            4. The tray will stay down until the first copy is made, then it will stay up.
