Interesting Ozone Filter Question...
  • Synaux
    • Mar 2012
    • 1224
    Today I was asked to look into a Ozone Filter Replacement error on a c650 (the filter is nearly identical to the c654--mesh is slightly different--c652 is the same too i believe). I advised that as long as there is no smell, a new ozone filter is most likely not worth be worth $50+ and simply reset the counter and blew it out even though it was spotless.
    I was asked if washing/rinsing them would be beneficial. I told em I would look into it. These are not the charcoal filters of old, but of metal-honeycomb-like construction. Can these be washed?
    Can anyone explain how these actually work?
    Thanks!
    Other notes:
    The c654/2 k drums come with ozone filters, the c650s imaging units do not.
    Here is a blast from the past on the subject (everyone seems so happy n shit):
    Ozone filters [Archive] - Copytechnet.com
  • rrrohan
    • Sep 2011
    • 1977
    Re: Interesting Ozone Filter Question...
    They come with and are replaced same time as K Drum?
    Do you have to manually clear the count? If so its possible maybe the last tech that changed the Drum just forgot to reset the counter.
    Or your pushing the Drums beyond life expectancy like most of us do on the 754 series
    • Synaux
      • Mar 2012
      • 1224
      Yes manually, it is a c650... there is no tech lol (and they are).
      With all due respect, that was not my question.
      • tulintron
        • Jul 2014
        • 668
        In the link you shared, Infiel explains exactly how it works and for what purpose it is there.
        with regard to cleaning, I believe there would be no problem washing, because the structure of today's filters is made of aluminum. Layers of aluminum form a mini hive, generating friction in the passage of gas along with toner particles, contaminating the hive pathways until it is clogged.
        our cleaning here in the laboratory and only through compressed air. we do this until the air comes out clean on the other side. obviously in a closed place with exhaust system and masks to protect you from impurities.
        in the washing system, I see that it would be difficult to clean because the contaminated toner gets too "stuck" inside the filter. already with compressed air, the pressure helps in the removal. who knows the two processes together ...
        WhatsApp Image 2020-01-22 at 09.50.37.jpgWhatsApp Image 2020-01-22 at 09.50.37 (1).jpgWhatsApp Image 2020-01-22 at 09.50.38.jpg
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          [ATTACH=CONFIG]44696[/ATTACH][ATTACH=CONFIG]44695[/ATTACH][ATTACH=CONFIG]44694[/ATTACH]
          I would think washing would not be good because when new, these aluminum o-filters are coated with a flat black substance (I always thought it was a thin coating of charcoal or something similar to absorb the ozone like the filters from the old days) and I would think washing them would remove this coating. This is all just guesswork on my part, though.
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • Bix
            • Apr 2018
            • 1421
            I don't know if it's true but someone told me that piles of toner could form which could form strange marks on the fuser
            • tulintron
              • Jul 2014
              • 668
              I agree with you and Bix, so just blow. But when I have the opportunity to exchange them, I have no doubts.
              • Synaux
                • Mar 2012
                • 1224
                Yes and no, as you say, as you say they are now aluminum (or similar material) nowadays.
                In the photos you attached, are the hive-pathways coated or bare or is that scraping sample simply an ozone-residue?
                My thoughts as well
                I honestly feel like this is a stretch... the ozone fan (filter aside) is intended to push materials burned by the coronas (perhaps laser too?) to maintain a somewhat ideal environment for the drum:
                Ozone ventilation fan motor (FM6)very slight amount of debris coming out when blown.
                • srvctec
                  • Oct 2009
                  • 827
                  I've never seen any plugged on these larger machines but then we haven't had any placed in super dirty environments, either. I can't remember in the last 30+ years if I've had an o-filter plugged on other machines in dirty environments or not. In my defense, I have C.R.S.
                  • Bix
                    • Apr 2018
                    • 1421
                    My biggest curiosity is... why does the Bizhub 227 have 3 filters to change (2 ozone filter + 1 toner filter)?
                    I don't know of any other bizhub with so many filters to change. To be on the safe side, I always change when the MFP requests it and its are actually very dirty after only 150k
                    • tulintron
                      • Jul 2014
                      • 668
                      Good Morning. I researched more deeply and I agree with you. This thin layer is charcoal.
                      • Synaux
                        • Mar 2012
                        • 1224
                        Thanks for the followup.
                        I was tempted to break into a new filter just to see for myself.
                        Out of curiosity, where did you find the info? I performed an auto-search for "Ozone" on ALL my documents with the results being less than elucidating (and my database only has a few items in it).
                          • 23006
                          Just as a side note:
                          Some charcoal filters can be cleansed by heat. Do you think warming would release the ozone to "refurbish" the filter?
