Bizhub C227 printing problems
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Got this machine installed @customer.
    It has problems with connectivity, sometimes it is offline.
    And prints, mostly PDF's coming slow.
    given in the end a time out problem.
    Also the operation panel responds slow when trying te get for example in the service mode, keys reacts slow.
    changed drivers, cables . . . No results.
    sending an PDF with the exact same driver to another C227 in the network no problems.
    Someone a clue here?
    Thanks in advance
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Bizhub C227 printing problems
    You failed to mention what version of F/W and what Function version the machine is at. Put the latest F/W on and set FV properly and see if that helps.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
      Originally posted by GeorgeBest
      Hi,
      Thanks in advance
      are you sure there is no conflict of IP?
      is the port used a WSD? (BIG NO NO )
      seeing how you haven't stated net config.. we'd be pissing in the dark to give further advice.
      • GeorgeBest
        • Jul 2009
        • 526
        No WSD, no conflict . . .
        • GeorgeBest
          • Jul 2009
          • 526
          Latest F/W
          version 4.2 (both)
          • tsbservice
            Field tech
            • 8010
            Hi,
            Thanks in advance
            Why print driver and Ethernet cable when machine panel isn't responsive?
            First you can do is to run full diagnostics, maybe then Initialize all data.
            • Bix
              • Apr 2018
              • 1421
              If the MFP goes offline, disable the SNMP port from the driver "Printer properties - Ports - Configure port ... - SNMP Status Active: remove the flag"
              For speed, I imagine that the C227 first wants to receive the whole PDF file and then starts printing, right? If so, just change these two settings in the driver:
              1. Printing preferences - Finishing - Paper layout: Productivity priority.
              2. Printing preferences - Quality - Bottom right "Font settings ..." - Download printer fonts: Image. Also remove the "Use printer fonts" flag.
              • copier tech
                • 8144
                Hi,
                Thanks in advance
                The fact that the operation panel is slow to respond you can rule out the network & drivers etc.
                You are on the latest function version 4.2 so as a test try disconnecting the HDD does the screen become more responsive?
                When the HDD start to fail they can "drag down" the rest of the machine making it perform slowly.
                If this improves back up the address book & format the HDD, its preferable to do a physical format however this can take hours to complete.
                • Bix
                  • Apr 2018
                  • 1421
                  Typically, the 227 and C227 do not have a responsive screen like a bizhbu C258. In fact, the C227 / 227 have a sensitivity very similar to the first touch screens of smartphones. We need to interpret well "it is not very reactive". The screen often requests the stylus for good accuracy.
