Color problem on c4050i,Help!
  • Noobies
    • Sep 2025
    the image results are not good on the c4050i (c3350i),
    at first the results are good, then a white line appears in the image,
    and it happens on two machines that have just been installed,
    has anyone ever installed the c4050i and got the same problem?
    *sorry for bad english
  • GIUBOSS
    • 1443
    Re: Color problem on c4050i,Help!
    both in print and in copy? What checks did you perform?
    • GIUBOSS
      • 1443
      So you are a technician and have you installed as per the technical manual? Send us photos of the prints
      • Bix
        • Apr 2018
        • 1420
        Hi, I have a C4050i with the same problem. I think it's a defective UI but at the moment, being that the customer doesn't print much in color, it doesn't happen often.
        I did a test pattern of all colors. I have discovered that the magenta imaging unit drops toner onto the laser glass. so when I print in color, a light white line comes out. With the PH Windows cleaner you can clean but it happens that after a few days of use, the problem reoccurs.
        • jwai
          • May 2018
          • 518
          So you report this issue to KM?
          • Bix
            • Apr 2018
            • 1420
            If you prove that you have updated the firmware and the MFP is new, you can pass it under warranty
              a competent tech would never go to KM with this simple problem.
              LASER GLASS
              check DEV unit and Image unit
              still waiting on examples
              OEM or crap 3rd party toner?
              • tsbservice
                Field tech
                • 8109
                As far as I understood they're talking about new machines. KM uses IU in this model and obviously some of these IUs are dumping almost from the install.
                I would claim it also.
