KM PagePro 4650EN
  • tsbservice
    Field tech
    • 8005
    KM PagePro 4650EN
    Hi All. Printer in question have 2 problems - Polygon motor malfunction 0300 and paper jams at exit section. Print counter is 35k.
    1. I replaced tray rollers with new.
    2. As PH unit and PRCB are not to be found and new are way over the price of the printer, I striped machine every connector, open PH unit and cleaned poly mirror.
    Now it works but still jams occasionally at exit. Sometimes it will print 30-40 sheets before jam, sometimes jams mightily every page.
    When paper stops page is almost exited but last few millimeters are at exit rolls. I can pull paper by hand and feel that printers stops to rotate exit roller.
    I have yet to study more manual to find out why there is no jam code but only jam message, it may be old model without jam codes though.
    I already put into this machine like 3 hours effort and want some advice from people who dealt with this model more than me - it's my first one.
  • Toxic
    • 697
    Re: KM PagePro 4650EN
    Did you notice little bit moved print position on paper? Registration problem?
    I also dont have much expirience with that model but have same problem on some others similar models.
    I dont know how it looks like specifically on that model but check everything regarding registration roller drive (clutch,solenoid,gear with torque spring inside).
    PS:i have one 4650 at low counter and it collecting dust for a few years.
    If you come somewhere to my direction i will donate it to you
    • tsbservice
      Field tech
      • 8005
      Thanks Toxic for your desire to help. I think registration is good but will double check it Monday.
      Regards
        • 14659
        I'm not familiar with this model, but is there a sensor at the exit? If so, it may be failing because of the heat from the fuser.
        • tsbservice
          Field tech
          • 8005
          I also have had problems in the past with failed exit sensors due to heat from fuser. I thinked down the same line as exit sensor here is actually in fuser.
          Unfortunately have no spare fuser to test though.
          • Toxic
            • 697
            By the book it could be sensor.
            I just found TAEU1200093EN00 and it explains how to modify exit guide and sensor actuator to prevent jam.
            Worth checking this also.
            • tsbservice
              Field tech
              • 8005
              Well if you be so nice to share with me this EU article TAEU1200093EN00
              • Toxic
                • 697
                NP,will sent in PM.
                • tsbservice
                  Field tech
                  • 8005
                  I nailed it, fingers crossed
                  Big Thanks Toxic!
