Konica 226
  • TOTO
    • Sep 2019
    • 21
    Konica 226
    Hi everyone my konica 226 show code c 2558
    Any suggestions
    Thinks
    Re: Konica 226
    Any suggestions
    Thinks
    get a service manual
    • TOTO
      • Sep 2019
      • 21
      Re: Konica 226
      Thinks
      Regards
      • copyman
        Owner / Technician
        • Sep 2005
        • 4788
        Re: Konica 226
        Never heard of a 226 but that code with Kon/Min means something wrong with toner or developer. You should be able to find a service manual online that will explain excatly what code is and how to fix it.
        Another option would be to make a small donation ($5 or $10) to this website and myself or someone will send you the manual.
        • REGSIS
          • May 2016
          • 440
          Re: Konica 226
          Any suggestions
          Thinks
          C2558 high TCR value.
          Open original cover/ADF and make 10ish copies.
          Paper should be full black. That will lower TCR ratio. Continue to work normally. If error reapears than repeat the procedure again.
          Depending of TCR value you may need to repeat it more or less times.
          If this doesn't help call the service to replace developer.
          Depending on machine's life (counter) drum or IUassy may need to be replaced also.
          • Toxic
            • 698
            Re: Konica 226
            I think he use non OEM toner and that cause this problem.
            • jwai
              • May 2018
              • 517
              Re: Konica 226
              It's a common issue on this model, although the genuine toner and parts are being used.
              You can adjust the TCR value first time, replace developer if it displays next time.
