C4050i with C - 5604
  • Roger67
    • Nov 2013
    • 84
    Hello,
    i have a brand new Bizhub 4050i who comes with a C - 5604 right after startup.
    There is no discription in the Manual about that .
    Any ideas ?
    Roger
  • tsbservice
    Field tech
    • 8020
    Re: C4050i with C - 5604
    Originally posted by Roger67
    Hello,
    Any ideas ?
    Roger
    Yes indeed I also can't find info about it.
    Try to run full self-diagnostics and start from there.
    • Roger67
      • Nov 2013
      • 84
      Hello,
      it seem that the problem comes from the Mass storage Board.
      Its not possible to install it or even deactivate it.
      I just ordered a new one.
      Roger
      • tsbservice
        Field tech
        • 8020
        Try FW first.
        • Roger67
          • Nov 2013
          • 84
          Hi Folks,
          after spending a couple of Hours i still have the C 5604.
          I changed
          PWB
          Storage Board
          BASEBOARD
          FW Version 79 is installed.
          The Code comes right after startup even bevor any Initialisation has started.
          Realy strange
          Roger
          • Bix
            • Apr 2018
            • 1421
            It could be some pinched wiring if you replaced everything. Have you tried contacting KM?
            What does self-diagnosis tell you?
            • Roger67
              • Nov 2013
              • 84
              Hello,
              no i dont have an Direct Contact to KM.
              For execute a CALL i need to go to an other Dep in our Company.
              Pinched Wiring is possible,but its even more difficult to find IT !
              The Self-Diagnosis tells me that everything is OK ( ? )
              Cheers
              Roger
              • Bix
                • Apr 2018
                • 1421
                Another attemp
                have you tried a trouble reset? Press the yellow button on the back of the display panel when you turn on the MFP.
                • Roger67
                  • Nov 2013
                  • 84
                  Another attemp
                  Yes,i i have don this several times.
                  • kurtjo
                    • Apr 2013
                    • 4
                    Hi.
                    Did you find a solution to the problem?
                    BR
                    Kurt
                    • and
                      • Oct 2011
                      • 97
                      Originally posted by kurtjo
                      Hi.
                      BR
                      Kurt
                      Error Code C-5604
                      C-5604 shows on a problem that is called "PH configuration error".
                      The problem is that the Print Head information that the Engine has and the PH information that is actually set, do not match.
                      Boards that belong to the system are not installed.
                      Please return the original boards back to the system
                      • kurtjo
                        • Apr 2013
                        • 4
                        Originally posted by and
                        Error Code C-5604
