C 2211 bizhup 350
  • Elias
    • Dec 2019
    • 12
    [Error Code] C 2211 bizhup 350
    hello
    I have this error code on this nice beautifull bizhup
    thanks in advance
  • tsbservice
    Field tech
    • 7955
    Re: C 2211 bizhup 350
    C2211: IU Motor Failure
    Relevant Electrical Parts
    -IU Motor (M2)
    -Mechanical Control Board (PWB-A)
    -Power Supply Unit (PU1)
    • copyman
      Owner / Technician
      • Sep 2005
      • 4596
      With age of that model it could be some of those things listed by other poster but I would look at something simple first, the image unit binding up or more likely the small gears that drive IU are stripped / binded. I had a lot of these old work horses at one time and never had to replace anything for C2211. But like I said as old as it is now anything is possible!
      • allan
        RTFM!!
        • 5462
        The gear on the motor also wears down.
        Big plastic gear vs metal motor gear, the metal gear fails.
        In the case that its the motor just replace it better would be to replace the motor and the drive.
        Whatever
        • copyman
          Owner / Technician
          • Sep 2005
          • 4596
          Hopefully you have a parts you can swap from. Not sure you will be able to get new parts for it, especially in Beruit.
          Best of luck
