Bizhub C368 Bootup Screen
  • tulintron
    • Jul 2014
    • 668
    Good afternoon.
    I'm on a C368 bizhub, but the option is disabled.
    Is there any dipsw or some configuration for the option to be unavailable on the panel?
    Nothing in the configuration manual, just installation
  • arahael
    • Mar 2013
    • 97
    Re: Bizhub C368 Bootup Screen
    Try firmware. Then emmc board faulty
    • tsbservice
      Field tech
      • 8008
      Are you positive that in System 2 - Import config data - BootUp screen tab is missing?
      • emujo2
        • Mar 2017
        • 1579
        this may be a result of USB connection settings being disabled, or enhanced securty set to ON. E
        • tulintron
          • Jul 2014
          • 668
          current firmware G00-K7
          enhanced security disable
          USB enable
          • copier tech
            • 8143
            Originally posted by tulintron
            Good afternoon.
            You cant disable the boot up logo by default is the KM logo or you can change it to your own.
            System 2>import config data.
            • tulintron
              • Jul 2014
              • 668
              Good morning guys.
              The solution for my case was to format the HDD in physical, disable HDD, base firmware until the most recent, format SSD, enable HDD, format logic, and finally the option I needed appeared.
              Thanks.
