Bizhub c368e printing out TX and RX reports?! How??
  • Chompers
    • Sep 2017
    • 5
    [Misc] Bizhub c368e printing out TX and RX reports?! How??
    Bizhub c368e is printing out TX and RX reports?! How is this even possible?? The machine DOES NOT even have a fax kit installed. Has anyone EVER seen anything like this??
    Chompers
    • 14711
    Re: Bizhub c368e printing out TX and RX reports?! How??
    Chompers
    What exactly is your question? Are you asking how to print a report? Or are you simply stating it won't?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4687
      • Bix
        • Apr 2018
        • 1421
        In the job list you can print a report, I think even if you don't have a fax kit installed.
        It also happened to me that some users independently downloaded the driver. Obviously they chose the FAX Driver, to send the fax from the PC. When they printed, the FAX format came out.
        • Chompers
          • Sep 2017
          • 5
          So, I was informed it prints out twice a day.
          Which still doesn't make sense Bix and Copyman, Copier Addict
          I will check if it is set for pc faxing, but some end-users want conformation
          on Transmit and Received faxes for their records TX RX . Maybe they chose to have
          the daily journal print out twice a day at certain a time(s) for PC faxing
          and don't know that they even did set up the report.
          Any other thoughts?
          Thanks for quick response.
          Chompers
          • Synaux
            • Mar 2012
            • 1224
            Any other thoughts?
            Chompers
            I know it does not have a fax kit, but is the fax "set" in SM?
            Is it printing reports or error reports?
            I'm with copyman in that I'm not sure what a RX report is either. There are a few hundred entries in the SM for RX. I went through good amount of them and got a headache. This might give you some direction:
            Report Settings
            [Service Mode] -> [Billing Setting] -> [Management Function Choice]
            I had some other thoughts too like changing the default to a tray they don't use (if possible) then set it to not print if no paper, but I think it would still save it in the user box either way and not sure if that applies to the "reports."
