BizHub Pro 1100 B/W Intermediately doesn't fold 11x17 properly 100% of the time
  • Tonersniffer
    • Nov 2012
    • 74
    Issue from day 1 of use. see attachment. Before I blame paper, has any seen this? Any suggestions?
    Also any one know where this goes?
    Thanks for your help!
  • tech51
    • 846
    • emujo2
      • Mar 2017
      • 1579
      Re: BizHub Pro 1100 B/W Intermediately doesn't fold 11x17 properly 100% of the time
      [ATTACH=CONFIG]45082[/ATTACH]
      thumbnail_20200226_165202_1582758088101_001001.jpg Bush part...E
      • sadanand
        • 62
        [ATTACH=CONFIG]45083[/ATTACH] Bush part...E
        This is in heater exit section ,your problem seems in exit section of heater check front side small rollers ,also check movement of black strip in exit section before copy reversal we are using paper upto 45 gsm
          • 23010
          Were the calibrations done on the finisher and booklet maker? I suspect not. Look at the setup instructions. =^..^=
          • Tonersniffer
            • Nov 2012
            • 74
            Thanks Furniture polish resolved it.
