Cant Access Web Connection on IPV4 Bizhub C280
  • cayyell
    • Feb 2013
    • 85
    [Misc] Cant Access Web Connection on IPV4 Bizhub C280
    Hi guys, recently facing a weird problem
    The C280 can be ping via IPv4, however I cant access the web connection but can access it with IPv6
    and the machine also cant print with the usual IPv4 port, but IPv6 can.
    Furthermore it seems like taking a bit of time to receive print data, which usually the data blue light will lid after I press the print, but not the case for this particular one. the blue light going to take few minute to light up.
    Is weird.
  • qbert69
    • Mar 2013
    • 1152
    Re: Cant Access Web Connection on IPV4 Bizhub C280
    Is weird.
    Have you tried doing a network interface reset through service mode?[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Gaffers01
      • May 2011
      • 335
      Agree with above.
      Also make sure its not there network before doing anything to the machine,
      plug your laptop into the machine and see if you have the same issue first.
      • cayyell
        • Feb 2013
        • 85
        Well because the location is quite remote, i was afraid that didn't work well so wanted to prepare myself whats next if the reset didn't work.
        Sorry I didn't mention it in the post
        • qbert69
          • Mar 2013
          • 1152
          Network reset in service mode is done physically standing in front of the machine!!![emoji41]
          • tsbservice
            Field tech
            • 8053
            That's right but if you have access to PSWC ie via TeamViewer you can reset network settings to the factory default status.
            In the administrator mode, select [Maintenance] - [Reset] - [Network Setting Clear], then click [Clear].
            • Synaux
              • Mar 2012
              • 1224
              That seems dangerous :P
              • emujo2
                • Mar 2017
                • 1579
                may be a browser security issue..Try running IE in compatibility mode, or try a different browser. E
                • cayyell
                  • Feb 2013
                  • 85
                  Nope is not, is a disaster
                  Tried chrome, firefox, and of course IE compatibility view.
                  PS: and I am not trying to fix it remotely, just wondering what else I can bring over to site if the network reset doesn't work.
                  • femaster
                    • May 2011
                    • 1519
                    Any idea if somebody at the clients office had been messing around in the web interface recently? Perhaps modifying the address book or something? I know it's possible to disable IPV6 connectivity from the Admin section of the web interface, but I can't recall if it is also possible to disable IPV4. If it is possible, perhaps someone has simply disabled it (accidentally?)
                    • cayyell
                      • Feb 2013
                      • 85
                      I dont think so, I was trying to locate the setting to disable web interface from the machine in my office, cant seems to locate it or I overlooked
                      • femaster
                        • May 2011
                        • 1519
                        Found this, looks like the setting you were looking for. Not sure if it will help, since you can access via IPV6. I'd think with it disabled, you wouldn't have access that way either.
                        • cayyell
                          • Feb 2013
                          • 85
                          [ATTACH=CONFIG]45103[/ATTACH]
                          Really appreciate the screenshot!!! Exactly my thought too, since I can access via IPv6 thats why I didn't put in effort to look for it
