Movie Data File 284e
  • casablanca
    • Oct 2016
    • 6
    Hi,
    Would anyone be kind enough to supply me with the movie data file for c284e please. Our machine is currently displaying the "no animation guide available message" after the HDD was reformatted.
    I will pay of course.
    Thank you
    Mark.
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: Movie Data File 284e
    Thought it was no e
    Gimme a minute...
    Ignore the first PM I thought it was a non e.
    2nd PM has the one you want.
    You are a contributor so I don't mind helping.
    • casablanca
      • Oct 2016
      • 6
      Thank you very much
      • casablanca
        • Oct 2016
        • 6
        Hi Again,
        That didn't work. I tried both files. Would there be a difference in software between Konica C284e and Develop 284e. I was under the impression they were the same just different name brand.
        Anyway we have the Develop 284e if you can help please.
        Thank you,
        Mark.
        • Synthohol
          • 5823
          how did you try?
          can you tell me the steps you took?
          you run the file i linked, it makes a .tar file, dont extract that. put it in the root of the flash drive.
          go to "install data" in service mode, plug in the usb in the front panel USB and hit set then start.
          what machine? you keep changing it, a color 284 is different than a b&w 284
          is it color or not?
          what are the first 6 digits for your main FW?
          • casablanca
            • Oct 2016
            • 6
            Panic over! I am using a mac so did what you said on a pc and everything works fine.
            Thanks again for your help.
