cs6500
+ More Options
Posts
  • Marc J
    cs6500
    I have a machine giving a 2213 code which is for the cyan drum. The blade does not flip and it can be reset. It is most noticable when running 12x18 heavy stock duplex. I have changed the drum drive motor and the printer control bd. I'm going to change the whole drum drive unit for the cyan drum next. Has anybody had this problem before?
  • random
    I suggest you do the (t/f) belt line speed before you start. If the problem persists swap the yellow drum shaft assy. I have had this but it was quite sporatic and ended up being the printer control board (upper right back of the machine)
    • tervel12
      • Dec 2008
      • 65
      Check your firmware version as well. There was a special release, 30-GCA, that allows you to change several dipswitches to alter the drum speed.
      • random
        Oh yeah! Completely forgot about that! Definatly check out the tech bulletin with regards to drum speed and those codes.
        • drodas78
          • Jun 2008
          • 91
          Can you send me that tech bulletin? I'm having same trouble. How do you fix it?
          tnx
          • ciuffe
            • Dec 2008
            • 2
            I have the same problem,
            could you send me this technical bulletin?
            Thank you
            • Vesigoth
              • Mar 2008
              • 133
              c6500
              hi guys. my c6500 is giving me an sc-2211 & I also have a c500 with sc2701. please help
              • holger
                When the drum motor/Y (M14)
                was ON, M14 abnormality
                detection signal was continuously
                detected for the specified
                time.
                Main body
                stops immediately
                and main
                relay (RY1) is
                turned OFF.
                Printer control board (PRCB)
                Drum motor /Y (M14)
                • tervel12
                  • Dec 2008
                  • 65
