MAC reporting image units expired
  • copier tech
    • 8236
  • Bix
    • Apr 2018
    • 1421
    Re: MAC reporting image units expired
    Of course, disable SNMP. The only problem is if you use monitoring software, it may not work
    • Bix
      • Apr 2018
      • 1421
      Check this: How to supress PM Part messages at end unser computers
      • jhalfhide
        • Apr 2015
        • 454
        Alternatively, instead of disabling SNMP why not change the community name and change accordingly in your monitoring software. That way nothing but the software will use it
        Sent from my LYA-L09 using Tapatalk
        • tsbservice
          Field tech
          • 8081
          Switch 230 deals with MIB (Management Information Base), I believe it will stop warnings for both MAC and Windows users.
          • copier tech
            • 8236
            Thanks, so SW 230 what HEX do I set?
            • tsbservice
              Field tech
              • 8081
              Set it to 'Not display'.
              • emujo2
                • Mar 2017
                • 1579
                I would advise against any changes to the SNMP string settings, or disabling the protocol. You may solve you MAC issues, but you will now have worse PC issues. E
                • Bix
                  • Apr 2018
                  • 1421
                  The best solution is to disable it from the driver. So it also solves problems of any "offline printer" reports. On Windows it's a very simple flag, on MAC I don't know.
                  • jhalfhide
                    • Apr 2015
                    • 454
                    You can update your changes driver side too. It's actually best practice in terms of network security, to not run standard SNMP trap names
