C454e C6104
  • jwai
    • May 2018
    • 508
    C454e C6104
    Hello,
    I have one C454e that display C6104.
    I disassembly and check the driving of CIS cleaning unit, it rotate several turns , the cleaning roller move when I manually turn the motor.
    The home sensor get bad? or other else?
  • Genotrom
    • Feb 2020
    • 77
    Re: C454e C6104
    Hi, start a load check, don't do it manually.
    I think it's 60 - 81 If you hear noise, stop and locate the stuck paperclip. If so, make sure that the sensor is not dirty and that the cleaning roller belt has not jumped.
      • 23008
      Re: C454e C6104
      Yeah, you can get the code if it's out of time. =^..^=
      • jwai
        • May 2018
        • 508
        Re: C454e C6104
        thank you all.
        as i checked that cleaning roller mounting unit, i found the back side lock lever cracked.
        so it slightly uneven width on the entrance of paper path.
        this condition will cause code?
        • allan
          RTFM!!
          • 5462
          Re: C454e C6104
          I would guess that could be the reason the belt would have jumped.
          Whatever
          • tsbservice
            Field tech
            • 8019
            Re: C454e C6104
            Check for cleaning motor broken mounts. Believe it or not there is FW update dealing with this issue. Not after it happened anyway.
            • jwai
              • May 2018
              • 508
              Re: C454e C6104
              Thank you for your prompt.
              I'm waiting for the jam release lock lever, I will check them also after the replacement.
              • blazebusiness
                SanDiegoCopierRepair.com
                • 1257
                Re: C454e C6104
                Originally posted by jwai
                thank you all.
                That condition will certainly throw the code because when the jam release door is not closed properly the brush rotation movement is "locked" until it is closed properly.
                Replacing the back side lock lever should solve your issue.
