C454 Jam J3205
  • selwag
    • Jan 2017
    • 1
    [Jamming] C454 Jam J3205
    Hello everyone.
    I have a problem with the C454 + FS533
    Jams occur behind the fuser, only when the inner finisher FS-533 is installed. When we disassemble the finisher it works great.
    I found a newsletter regarding this error J3205, they recommend lowering the temperature on the fuser.
    Maybe someone has already encountered such a problem?
  • barber782
    • Aug 2011
    • 286
    Re: C454 Jam J3205
    Iv always...
    Updated firmware
    Decreased the fuser temp by - 5
    Lowered the fuser transport speed by 2
    Removed the noise damper pads for the exit/duplex gate, located on the exit assembly and Upper door, as the gate can stick.
    Fit modified part for the exit solenoid. As the gate doesn't always open/Close far enough. See attached photo.
    On the odd occasion iv had to adjust reg loop adjustments, but not sure that will help you.
    If it jams constantly an inch after fuser then the exit clutch might be suspect. You can usually tell if it's the clutch as you will find orange rust around the top of the duplex door hinge.
    If I can think of anything else I will let you know.
    Sent from my VTR-L09 using Tapatalk
    • avecosat
      • Jun 2012
      • 305
      Re: C454 Jam J3205
      One solution is to stretch the solenoid spring a little.
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        Re: C454 Jam J3205
        Originally posted by selwag
        Hello everyone.
        You see that picture posted of the solenoid?
        Another way is to put a 1-2mm shim in front of the solenoid, on the frame, it lowers the gate a tad at resting position. It seem the gate shuts just a tad slow, so the paper either Nick the gate or goes to the wrong place (as on finding paper behind exit)
        Idling colour developers are not healthy developers.
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1257
          Re: C454 Jam J3205
          Hello everyone.
          Those internal finishers have a known issue of not timing correctly with the C454 MFP and causing jams.
          If the 3205 jams are due to paper curl , Then just set fuser warmup mode to mode 3 and decrease temp by -10 degrees. Almost always fixes it. (attaching techpub for J3205 issue below)
          But, If the jams they are having are due to improper timing between those crappy internal finishers and the C454 MFP - we usually just upgrade the customer to a FS-534 finisher.
          Some tech's have had success lubricating the main body exit assembly bushings to deal with the timing issues on the C364's and C454's. The slower speed 4 series machines don't seem to suffer the same internal finisher timing issues.
          Bizhub 4 series duplex Fuser Jams J32-05.pdf
