C70hc Freezes on the home screen
  • Destak Produções
    • Mar 2020
    • 8
    Good afternoon.
    I have a Konica Minolta machine bizhub press c70hc this morning I went to turn it on but it froze on the startup screen with the following message Please Wait, System Starting and the power save button is blinking and it won't go away.
    Could anyone tell me what happened? I used it on Saturday 14/03/2020, I turned it off normal and today no longer calls..jpeg.jpg
  • GIUBOSS
    • 1385
    Re: C70hc Freezes on the home screen
    it could be an hdd problem
    • Destak Produções
      • Mar 2020
      • 8
      Is there anything I can do to check if it comes back?
      • tulintron
        • Jul 2014
        • 669
        Good afternoon.
        Could anyone tell me what happened? I used it on Saturday 14/03/2020, I turned it off normal and today no longer calls.[ATTACH=CONFIG]45271[/ATTACH]
        Good Morning. You made two posts about the same problem. Not necessary.
        I'm from Minas, maybe I can help you. I'm talking to
        a technician about your problem. You are an end user and you will not be able to solve it yourself. You need the correct firmware and technical knowledge to solve.
        • Destak Produções
          • Mar 2020
          • 8
