Firmware Bizhub 215
  • escalante
    • Sep 2018
    • 115
    Firmware Bizhub 215
    Install the GDI drive in the computer as indicated in the section rewrite the firmware.
    When I click on update it gives me that message.
    I have to enter the technical service mode of the machine to receive the new firmware.
    Enviado desde mi SM-J701M mediante Tapatalk
  • copyman
    Owner / Technician
    • Sep 2005
    • 4675
    Re: Firmware Bizhub 215
    Thank you in advance for your response.[ATTACH]45272[/ATTACH]
    What are you asking? How to enter service mode or need Firmware? Perhaps someone else will tell you how but personally I don't give that information out, especially to a NON contributer. An end user can do too much damage in the service mode. FYI the last FW for that old model was around 7- 10 yrs ago!
    There are some on here that give out this info thinking it makes them look good but actually makes us all look bad.
    Not saying you can't work on your own machine or maybe you are a tech. Either way a small contribution helps this site and members here will share manuals, F/W & their knowledge more easily.
    • rrrohan
      • Sep 2011
      • 1977
      so you installed device driver.
      You then connected to copier with a usb cable then launch UpdateFW.exe
      you dont need to go into service mode to update the firmware
