C364e recurring C4091 code
  • mascan42
    • Oct 2008
    • 485
    I have a C364e that throws a C4091 error every couple of days. In the error history, it also shows CFA14 right after rebooting from the other code. I replaced the MFP board, but it started back up a couple of days later. Occasionally, it will stick at the logo screen when the customer reboots it (no idea if they're doing something wrong or not - I've never actually seen it happen). Any ideas?
    Re: C364e recurring C4091 code
    HDD / firmware?
    • tsbservice
      Field tech
      • 8020
      MFPB is on one part of this code, on another is PCRB as you know.
      May be SSDB as well. I would perform an all data clear and SSDB format before replace other parts.
      • tsbservice
        Field tech
        • 8020
        Phil, thank you for your comments.
        I have a lot of respect for you Brother.
          Same from me Brother!!
          and i know if I do misspeak you'll let me know where I went wrong also!
          • copyman
            Owner / Technician
            • Sep 2005
            • 4718
            Use the SSD firmware reset tool and you should be good to go.
            If you need the firmware make a small contribution to this site and will send it to you.
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              Also can be caused by the flat cable between the MFP board and PCRB pcb causing a communication issue. Try reseating that flat cable and inspect it for damage.
