Bizhub i series tip
  • tsbservice
    Field tech
    • 8020
    Bizhub i series tip
    All folks here know how stupid is to fool yourself.
    Nonetheless it happened to me 2 times in last months to try to enter CE mode on bizhub C250i and cannot.
    The reason was that in all my stupidity I was left PSWC logged in Administrator mode.
    Draw a lesson and save some minutes next time you cannot enter in CE password screen, check for PSWC session logged in Admin mode. If so logout and try again.
    • 23009
    Re: Bizhub i series tip
    I've done it plenty of times myself. =^..^=
    • emujo2
      • Mar 2017
      • 1579
      Another thing I hate about the 8 sereis and newer..If you are in PSWC admin the users can still walk up and use the machine..Nothing like spending several min configuring the device only to find out that "unable to process due to active job". Not bad if it's a couple of pages, but I have had users run 50 page faxes through..Now your stuck for 40 min..E
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        This is exactly why the very first thing I do on a service call is to disconnect the fax and network cables. The only time I won't do that is if I'm only servicing the ADF. They can still print and receive faxes while I'm working on that without causing an issue.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • tsbservice
          Field tech
          • 8020
          Good point 👍
