C6501 throwing C4101
  • kokkerbrick
    • Jan 2007
    • 12
    [Error Code] C6501 throwing C4101
    Hello to all
    I have a C6501 that shows C4101.
    At first it showed C4104. I took out PH unit K , cleaned it very carefully ,lubricated polygon motor , put all together again .
    Machine started and showed C4101 (PH unit Y).
    After that I cleaned all PH units, I also changed the fans on the backside of the laser to see if its a "phantom code"
    I also switched lasers C-Y and still nothing
    Any ideas?
    Thank you
    Pascal
  • tsbservice
    Field tech
    • 7981
    Re: C6501 throwing C4101
    Check ICP5 on the PRCB. If open verify the operation of M43. If needed replace M43.
    • GIUBOSS
      • 1385
      Try here: https://www.copytechnet.com/forums/k...tml#post466832
      • kokkerbrick
        • Jan 2007
        • 12
        Hello
        I check all ICP , they're all ok. Also M43 chacnged. Same problem
        • kokkerbrick
          • Jan 2007
          • 12
          Originally posted by GIUBOSS
          I checked this first of all.Its not the case
