KONCA MINOLTA c364e
  • BAOMAR
    • Apr 2020
    • 3
    [Error Code] KONCA MINOLTA c364e
    Hello
    i want firemware c364e
    thanks for help please.
  • tsbservice
    Field tech
    • 7998
    Re: KONCA MINOLTA c364e
    What problem you have? Are you an enduser or tech?
    • BAOMAR
      • Apr 2020
      • 3
      enduser
      air print no activate
      web browser no activat
      iwant to activate all please.
      • tsbservice
        Field tech
        • 7998
        The optional Upgrade Kit UK-204 and i-Option LK-101 v3 are required to use the Web browser function on this machine, do you have them?
        As for AirPrint you need as minimum firmware G20-J6 which is rather old and many newer versions are available.
        • femaster
          • May 2011
          • 1489
          Re: KONCA MINOLTA c364e Airprint
          Originally posted by BAOMAR
          enduser
          Browser requires additional hardware, as tsbservice indicated. Firmware that supports airprint is quite old, so I'd hope that your copier already is capable, but just needs to be enabled. It is disabled by default. Check out this YouTube video and it will show you how to enable it.
          YouTube
          • Copier repairman
            • Aug 2019
            • 86
            [QUOTE = BAOMAR; 1445791] 안녕하세요
            내가 firemware c364e의합니다
            . 도움을 주셔서 감사를 바랍니다 [/ QUOTE]
            Fighting!
            I wish you victory ..
