Problems c452 print dust
  • karimharaka
    • May 2012
    • 11
    i have konica minolta c452 which print dust. i have changed the laser bloc, transfert belt, controller board. imagine unit. all of these are not worked. ( i still do not replaced the graphique board!!) this is the last chance 962B8362-0B67-4E5C-88EB-B4B675FD6351.jpg
    i need your help
    thanks
  • GIUBOSS
    • 1437
    Re: Problems c452 print dust
    Which image units did you replace? Did you perform the calibrations at each replacement? Try to print from PC only in B / W
    • karimharaka
      • May 2012
      • 11
      i have another imagine unit which works will in other bizhubc652.
      could someone send me firmware of bizhub c652 because i changed the main controler board PROBLEM C164
      karimharaka@gmail.com
      many thanks
        many thanks
        sounds like you rushed in your troubleshooting process. image problems CAN be some of the easiest fixes there are.
        • tsbservice
          Field tech
          • 8081
          Backgrond when copy or print or both?
          Backgrond on color or B&W?
          Backgrond has developer or not?
          What's the color of backgrond?
          From your small picture and incoherently description it's hard to help you.
          • emujo2
            • Mar 2017
            • 1579
            I'm assuming by print dust he means background..Did you run the stabilzation, and gradation adjustments after replacing any of the items you mentioned? E
