Konica Minolta C754e Squeaking Noise When Idle
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C754e Squeaking Noise When Idle
    Getting Squeaking Noise in Konica Minolta C754e when Idle
    Is it from Fuser Assembly Like in C554e or from the exit roller drive gears assembly lin C452/C652?
    Please advise.
    Many Thanks
  • copyman
    Owner / Technician
    • Sep 2005
    • 4786
    Re: Konica Minolta C754e Squeaking Noise When Idle
    Please advise.
    Many Thanks
    It's most likely the fuser unit cleaning roller bearing & small bushing has worn and roller shaft is now metal to metal making the noise. Can happen to low volume users as well, maybe even more. Because this became so common they sell the cleaning roller parts separately for that fuser. Usually you need to replace the cleaning or brush roller, bearing & bushing. I usually replace both rollers, small bushings & bearings all at same time.There are aftermarket cleaning & brush rollers that work just as good as OEM, if not better.
