Bizhub c224
  • eli
    Not a technician
    • Oct 2014
    • 40
    Bizhub c224
    Hello. Can anyone please send me firmware or what is needed to completely wipe and restore a c224 machine? I know that firmware is not available online and that i should get a tech. However, this is at a remote location, so that is not an option. I have a few issues with the machine, like changing admin password, etc. If i could get firmware for c454e as well, taht would be great. Thanks in advance.
  • allan
    RTFM!!
    • 5462
    Re: Bizhub c224
    Change admin password in service mode if that is the only real issue.
    There are very little reason to ever clear the entire machine unless board changes were made or the machine was locked on purpose and someone else is trying to unlock it.
    For resale there are procedures to be done that does not involve firmware.
    Whatever
    • eli
      Not a technician
      • Oct 2014
      • 40
      Re: Bizhub c224
      There are very little reason to ever clear the entire machine unless board changes were made or the machine was locked on purpose and some one else is trying to unlock it.
      There are many other issues actually. Faxes are sent as emails. Many settings are missing. The fax module is in place.
      How can i completely reset it to factory settings?
      • allan
        RTFM!!
        • 5462
        Re: Bizhub c224
        Service mode > System1 > initialization
        The instructions to set/unset forwarding a fax to an email address and to set it to print would be under admin settings.
        Whatever
        • eli
          Not a technician
          • Oct 2014
          • 40
          Re: Bizhub c224
          Ok, will do. This will basically delete ALL data and settings from the machine, correct?
          • tsbservice
            Field tech
            • 8007
            Re: Bizhub c224
            Use the power...just kidding. Get the service manual.
            • eli
              Not a technician
              • Oct 2014
              • 40
              Re: Bizhub c224
              Ok read the manual, i get it. Last question, what can possibly go wrong?
              • allan
                RTFM!!
                • 5462
                Re: Bizhub c224
                Fix your admin password issue first.
                You will loose the network configuration settings, and could possibly need to set the HDD again.
                Other than that not much.
                Whatever
                  Re: Bizhub c224
                  +2 on this
                  • copier tech
                    • 8142
                    Re: Bizhub c224
                    Happy to help drop us an email
                    www.copierfirmware.co.uk
                    • eli
                      Not a technician
                      • Oct 2014
                      • 40
                      Re: Bizhub c224
                      Admin pass is set to default which is ok but setting is missing in http.
                      How do I set the HDD? Through service menu?
                      • eli
                        Not a technician
                        • Oct 2014
                        • 40
                        Re: Bizhub c224
                        Decided not to clear data. Will start a new thread regarding a fax issue.
